주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 7월 출시, 15" MacBook Pro, 모델 A1990, True Tone 기술이 적용된 15.4인치 LED-백라이트 디스플레이, TouchID, 및 최대 6코어 Core i9 프로세서를 탑재했습니다.
Start without power buttom
Problem Description
I have a 15-inch MacBook Pro 2018–2019 (A1990). The battery is connected, but it is completely discharged, so the MacBook is currently powered by the charger.
The problem is that:
  • the power button is not working;
  • Touch ID is also not working;
  • I previously disabled automatic startup when opening the lid using Terminal;
  • I also cannot properly press the power button.
As a result, the MacBook is connected to the charger, but I cannot turn it on using any standard method.
My Question
How can I safely turn on a MacBook Pro A1990 without a working power button or Touch ID, if automatic startup when opening the lid has also been disabled? Is there a safe way to trigger the Power On signal without using Touch ID?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sorry don't have any good answers which can solve all of your problems.
To start off if you are able to get the system running in its current state I would immediately backup your system so you don't loose all of your stuff and the current setup.
Instead of trying to gain direct access if you can get the system to power up since you state the Power/TouchID button is not working, if you have a second Mac system which you can connect to and have access to same iCloud account you should be able to treat the MacBook as an external drive to salvage your data.
So let's get into the needed repairs a bit...
Clearly you need a new battery at least, and if the Power/TouchID button is damaged replacing it will require a full system wipe to then connect a fresh Power/TouchID button only Apple can do that. But it does sound like the logic board still has issues which would require replacing or if you can find a talented Mac repair person who has the chops to dive deep into the circuitry they maybe able to repair the logic board instead.
You'll need to tally up the costs and decide if the outlay of funds is worth it! You might find a used system which is newer of if you can live with a 13" display the Neo is quite nice!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks. But I need start it. No start pads on motherboard?
의
@semi72933 - Did someone disconnect the Power/TouchID ribbon cable and or take the button fully out?
Let's hope the Power/TouchID ribbon cable is not damaged and/or the ZIF Connector's compression bar is present and latched.
It's a very thin cable which can get damaged trying to take the button out. Here's the Button so you can see how thin it is passing through the case MacBook Pro 15" Retina (Late 2016-2019) Power Button so while iFixit offers the button TouchID won't work as the button and logic bd are married to each other! This is how Apple prevents access to your data by others!
의
댓글 달기
답변을 추가하세요
Semi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 81
