주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP LaserJet 1020은 개인 또는 소규모 홈 오피스를 위해 설계된 콤팩트한 흑백 레이저 프린터입니다. 최대 1200 dpi(유효) 해상도로 인쇄하며 인쇄 속도는 분당 약 15장입니다. 고용량 토너 카트리지를 사용하여 기본적인 흑백 인쇄 작업 시 경제적입니다. 무선 연결이나 컬러 인쇄와 같은 현대적인 기능은 없습니다.
Paper not going in
I don't know what's broken but the printer tries three times to pull the paper and fails and then tells me there's no paper
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I have an old hp laserjet p1102. Looks similar to yours. Getting a bit old (2005 vintage!) which means the rubber paper feed roller is hard and has lost its grip. If you can reach it (it's the oval shaped roller in the centre of the feed at the top) clean it with a rag dipped in meths or benzine. This often softens the feed rubber but isn't always a permanent cure.
Here's what I do when it tries to pick up the first paper in the feed deck (I hear three or four distinct clicking sounds as it tries to grip the sheet). I got myself a rubber finger tip which I use to gently push the sheet in while it tries to feed it making the clicking sounds. Once it takes the sheet, stop feeding it by finger. Also make sure your paper deck is not too thick or too thin, is stacked neatly and square and pushed in all the way into the paper take up slot. Once the first sheet is finger tip fed in and taken up and the rest positioned as above, the following sheets usually get fed in normally.
Each time you replace the stack, feed the first one in by finger.
In days gone by one used to get paper feed replacement parts for these printers. Maybe you can try - which is a long shot - else go for the cheap rubber finger.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
FaaMs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 104
