주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson Xperia Play는 PlayStation 컨트롤이 탑재된 컨트롤러를 특징으로 하는 최초의 Android 휴대전화입니다.
Half of touch screen not working
The top half of the touch screen on my Sony Ericsson Play (R800i) is unresponsive. I can't get past the passcode to do anything through the menus.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
I repaired one of these the other day and initially replaced the digitiser which didn't solve the problem..turned out to be the slider flex. If I'd followed my hunch that it was the problem I could have saved myself a whole lot of tooing and froing taking it apart and resitting connectors. Take a good look at the slider flex, it's the most vulnerable part..if it looks worn or kinked from all the sliding then I'd replace it first. I don't recall it being part of the step by step guides and had to work it out for myself.. follow the guide for the display removal and then you'll see how the flex feeds through the bottom portion etc. It has 2 simple flip connectors and uses adhesive tape to keep it in place.this is the part I ordered in the UK, I'm sure you can get them in other countries.
As only half your screen is unresponsive it does sound like the digitiser (touchscreen) is the problem like this
for the slider flex Sony Ericsson Xperia Play 디지타이저 교체 and at step 11 flip over the silver backing of the top slider portion and you'll see the flex and it's attachment coverings..I managed to work it out.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks for the prompt suggestion.
의
댓글 달기
답변을 추가하세요
Goose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 4
지난 30일: 30
전체 시간: 14,917
