Pc automatic shutdown no display no function
Whenever I turn on my PC, it gets switched off within a few seconds, neither the display comes on nor the mouse or keyboard works, the fan stays on for some time and then gets switched off.
좋은 질문입니까?
That sounds like a hardware problem. Start with the easy stuff. Unplug the PC, open the case, and make sure the RAM is seated properly. Also check that the big power cables going to the motherboard are firmly connected.
If you have two RAM sticks, try starting it with just one at a time. If it still shuts off before you get any display, the power supply or motherboard could be the problem.
Don’t start buying parts yet. Check the simple things first.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 6
지난 30일: 6
전체 시간: 6
