주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
터치 기능과 모터 구동 방식이 적용된 Nespresso 커피 머신입니다. DeLonghi EN110 또는 Krups XN250110 등의 모델명으로 판매되었습니다.
XN250 O-Ring replacement
Greetings,
My Nespresso U Krups XN250 suffers from water leak. Looking at how the machine behaves with the cover removed I do suspect O-Ring is torn. I'd like to try to replace it, but I just can't reach the ring. It looks like in order to do it I need to remove moving part (piston? MS-623324, see the picture), but I have absolutely no clue how. I dont see any screws, cant move gears manually to move the part to the edge position etc. Please advise.
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
In order to move the part in the image forward you need to ensure that the machine wasnt in the middle of a cycle while it was still in use. If the housing is not near the front of the machine then plug the machine bakc in, press one of the buttons so it starts filling up a cup and allow it to finish it cycle. It should then move to the forward position. Its quite a challenge removing the part from the rest of the machine, though. Just be sure to pille the main, grey plastic to the sides and "bend" It out of the way enough that you can pull the part upwards. You should then be able to easily find what yoh need to
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Maaaah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 40
전체 시간: 118
