주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Makita XDT08은 전문가용으로 설계된 무선 임팩트 드라이버로, 브러시리스 모터가 탑재되어 있으며 18V LXT 리튬 이온 배터리와 호환됩니다. 5-7/8" x 3-1/4" x 9-1/8" 크기와 1/4" 육각 드라이브를 갖추고 있어 다양한 체결 및 드라이빙 작업에 강력한 토크와 속도를 제공합니다.
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brian Taylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 36
전체 시간: 81
