주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mercedes-Benz W126은 1979년부터 1992년까지 메르세데스-벤츠에서 생산한 S-클래스 자동차 시리즈입니다. W116 라인의 후속 모델로 1979년 9월에 첫선을 보인 W126은, 독일어로 '특별한 등급'을 뜻하는 'Sonderklasse'의 약칭인 S-클래스라는 명칭을 공식적으로 사용한 두 번째 세대입니다. W126 세단은 초기 직렬 6기통, V8 및 터보차저 디젤 엔진 사양으로 출시되었습니다. 1981년 9월에는 C126 2도어 쿠페 버전이 추가되었습니다.
auto trans dip stick
I have an 84 merc 300sd. I can't get the locking cap on the trans dip stick to release so I can pull the dip stick.. I think it has a missing or broken part. I think there is supposed to be a lever that releases it. I just got the car so I'm not sure what the problem is. The cap will rotate and will pull up slightly but won't come out. Can I force it ? If so how? If I break it in the process of removing it, do you know where I can get a replacement? Thanks for your advise.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
On an ’84 300SD, I wouldn’t force it yet. There is supposed to be a locking lever on that cap. The black piece underneath the red cap swings up and releases the clamp around the dipstick tube. Once that lever is released, the cap and dipstick should come out.
If that little lever is missing or broken, that may be exactly why you’re stuck. I’d look closely underneath the cap and see if there’s a small black hinged piece you can get a finger under. Don’t put a pair of pliers on the cap and start twisting it yet; it’s old plastic and you’ll probably just make the job more expensive.
There are replacement locking caps available, and Mercedes owners have been replacing these for years.
One other thing: once you get it out, check the end of the dipstick. These old Mercedes sticks can have the rounded end broken off, which can make the level markings misleading.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Where can I get a replacement? The only one I've found is in the UK and very expensive to ship. Where can i get one in the USA?
의
댓글 달기
답변을 추가하세요
tom campbell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 29
전체 시간: 36
