주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace the screen?
Reason why I am asking is because my aunts dog jumped on her tablet and cracked the screen
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The Tab S10 FE 5G is definitely repairable, but the screen replacement is a fairly involved job. Samsung’s service manual says the screen is heavily adhered and specifically calls for a large suction cup and heat to separate it, with extra care around the battery and internal components.
I’d first confirm whether only the glass is cracked or whether the display and touch are also affected. If the LCD and touch still work normally, you still generally replace the complete screen assembly rather than trying to separate the glass yourself. The basic process is to heat the adhesive, carefully lift the screen, disconnect its flex cable, clean the old adhesive, connect and test the replacement, then install new adhesive and press the screen back into place. Samsung specifically recommends testing the assembly before fully sealing it.
The big warning is the battery. Don’t push a pry tool deeply into the tablet while separating the screen, and don’t use excessive heat. With a cracked screen, Samsung also recommends taping over the broken glass and wearing eye and cut protection before starting.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Casey Teska 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 42
지난 30일: 169
전체 시간: 237
