주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 iPhone SE는 3월 9일 (미국 시간 3월 8일) 신제품 출시 행사 Peek Performance Apple에서 소개되었습니다. A15 칩과 4.7인치 LCD 디스플레이가 특징입니다.
NFC antenna does not work
Hi, I’ve had this issue going onto a year now. It started from when I took out the logic board the first time to swap the charging port.
Everything else works except the nfc antenna and the back camera. I’m unable to use wallet to pay for stuff and my back camera doesn’t work.
After about a year my housing breaks so I swap the housing with a preowned one from eBay. Zero brackets missing yet the problem persists. I don’t know much about how the antenna works but I do know that it has something to do with some screws. Perhaps I’ve mixed a couple up?
I did lose the screw under the WiFi antenna that is unthreaded partially. I replaced it with spare screw that fits snug. Maybe that’s causing it? But then again it was screwed in on the previous housing and the issue remained.
Any helps much appreciated. Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Since both NFC and the rear camera stopped working after the first logic-board/charging-port repair, I’d suspect a connector, flex, grounding point, or board-level damage rather than the housing itself.
I’d retrace the original repair and check every connector and screw/grounding point, especially around the camera and NFC circuitry. If you can pull a panic log, an iPhone panic log analysis may also reveal a related hardware communication fault.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Neryk Hernandez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 64
전체 시간: 64
