주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 출시된 Epson EcoTank 시리즈 프린터.
My computer reads no paper in printer
My computer reads "no paper" in the printer. There is paper in the printer.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
let's see if our printer Guru @nick has more ideas about this.
의
댓글 달기
답변 1개
가장 유용한 답변
These are top feed and the Epsons are prone to dust at the top causing issues with this mech - always have. What you need to do is run inkjet cleaning sheets through the feeder, and what I have also done is used canned air to get rid of as much as I can to make it effective.
If the issue still occurs with a cleaning, there's an issue with the sensor or the gears. If you are using standard 20-24lb paper try cleaning it, then clean the sensor if you can access it. The desktop models like this are integrated tightly, to the point you can't easily service them. The SM readily available here: Service Manual
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Bill Hepper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 52
전체 시간: 52
