주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen ID.5는 독일 자동차 제조사 Volkswagen에서 생산하는 순수 전기 소형 크로스오버 SUV입니다.
Code p00AF00 appears on the scanner
Code P00AF00
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This is a Turbocharger/Supercharger Boost Control A Module Performance code on the gas/diesel engines, you picked the wrong car. That said, there's still some things we can mention without a year. You want to make sure the actuator/linkage for the turbo is not damaged or worn first, as well as checking any vacuum lines and connectors - if you can do so, take any connectors you see off and then spray CRC QD on any connectors you disconnect. Reconect everything and then clear the code and then drive it for 10-15+ miles to see if the codes come back. You need an all systems scanner for this to properly clear and test it, a cheap one will not work.
If it continues, I would check the health of the turbo - look for anything in the tubing and see if the bearing runs freely - if it seems tough to spin by hand, you may need to replace the turbos as the bearing is going out. If you do not see anything in there and it spins freely, you may want to try to change the actuator linkage if it isn't part of the turbo.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Maache Yousfi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 59
전체 시간: 59
