주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 3 A315-58-350L은 Acer Aspire 3 보급형 노트북의 개정 모델입니다. 대학생이나 이동이 잦아 가벼운 노트북이 필요한 직장인과 같은 일반 소비자 시장을 겨냥해 출시되었습니다.
Keyboard and power on off button doesn't work.
In my laptop doesn't work keyboard since 4 month and recently I getting new problem I noticed that my laptops power on off button it also not working, that's why I'm not able to get start my laptop.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@yogeshprajapti sounds like the keyboard failure has now extended to the power button's internal circuitry, preventing the laptop from turning on.
Remove the lower case. Unscrew all fasteners on the bottom panel and use a plastic prying tool or card to carefully release the clips around the edges. Next, disconnect the internal battery. Locate the cable that connects the main battery to the motherboard. Gently pull the connector straight out of its socket to disconnect it. Leave it unplugged. Now, reseat the keyboard cable. Lift the plastic locking flap on the connector, slide the cable out, and reinsert it completely to rule out a loose connection. Press the flap back down to lock it. Next, try to bypass the power button. While the internal battery is still completely disconnected, open the laptop screen and plug your AC adapter into the wall, then into the laptop. Connecting AC power while the battery is disconnected should force the motherboard to boot automatically. If the system successfully boots into Windows, carefully reconnect the internal battery to the motherboard and reinstall the bottom cover. If the laptop remains completely unresponsive, the complete keyboard palmrest assembly must be replaced to restore power functionality. To work on it, use the guides from here Acer Aspire 3 A315-58-350L and videos like this (slightly different model but same idea) to augment those guides.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
yogesh prajapti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 20
전체 시간: 20
