주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 9월 24일에 출시된 iPhone 13 Mini는 Apple의 iPhone 13의 소형 버전으로, 두 번째 미니 iPhone입니다. 5.4인치 OLED, A15 Bionic 프로세서, 듀얼 후면 카메라가 탑재되어 있습니다.
Changing Display and Proximity Sensor
Hi, I have rather a specific issue with this iPhone. It has been given to me as a second use phone and I decided to repair it. From my knowledge the display is a third party item (LCD I think), the touch is likely dead (unresponsive) I do not think something is wrong with the flex cable itself as it seems undamaged to me. And also the connector at the end of the flex cable for Proximity Sensor has 2 pins chipped off.
My question is. Is it worth it to try and bring to a working state? Would buying a new Proximity Sensor fix the unresponsive display? The FaceID?
Thanks for any reply.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
A new proximity sensor won’t fix an unresponsive touchscreen. The touch issue is more likely the third-party display, its flex cable, or the connector on the logic board. I’d test with a known-good compatible display first.
The damaged proximity sensor flex may affect proximity functions, and if the damage involves the original TrueDepth/Face ID components, Face ID may also be affected. Don’t replace those parts blindly; identify exactly which connector is damaged and test each issue separately before spending more money.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Pracovny 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 84
