주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
작동하지 않거나 간헐적으로 작동하는 Maglite를 수리하세요.
Why does this MagLite not work?
After removing the rubber button, an allen wrench loosens the Assembly, to then slide out from the Tube/case.
The On/Off switch works when connecting 3VDC Plus to A and Minus to B.
When the Assembly is installed in the Tube, it all works when connecting 3VDC to that A point (via a long screwdriver) and C (the rim of the Tube).
I even confirmed that there Is continuity from D (which Does press against the battery when assembled) and E.
The batteries Are good/full.
I cannot figure Why it won't work when put together.
Mark578
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 14개:
Is the bulb showing continuity?
의 공유
@honakrisi
Continuity? Maybe I don't understand your question.
When the switch is at On, the bulb lights and stays lit.
의 공유
I suspect one of the following might be the case:
・The continuity state changes when the unit is assembled and pressed (between D and E, or at point A).
・There is a specific point where continuity between E and C degrades when the screw is tightened.
의 공유
OK, I checked the Continuity of the bulb.
Yes, there is continuity between the two contacts on the bulb.
의 공유
Further confusion:
With a Universal Power Adapter, output set at 2.85 VDC (and the voltmeter confirms that), connected at A and B, it works.
It takes quite a bit of pressure to screw the rear cap onto the Tube
when the Assembly and batteries are in (putting it all together),
so I thought that maybe there's too much pressure on A
(some broken connection Inside the Assembly?),
so I connected the Universal Power Adapter 2.85 VDC,
pushing Very Hard on A. It still works.
When the two batteries are lined up together, a voltmeter shows there is 2.94 VDC.
Add the Assembly (not inside the Tube) to that line, so A is touching battery #1 Plus, and a piece of wire from battery #2 Minus to B (in my 3rd picture): it does Not work.
I've tried using "Panasonic Super Heavy Duty C" batteries, and "Eveready Classic C" batteries; none will work.
My conclusion so far: this thing won't work, even using GOOD batteries.
But it does work with 2.85 VDC from another source. WHY?!
의 공유
댓글 9개 더보기
댓글 달기
답변 1개
11/20更新
その後、何か進展はありましたか?よくよく考えてみたのですが、以下のところが気になってきました。
ねじがダメージを受け締まり切らず、または少々腐食して接触が悪くて、ポイントCとポイントEの接触があまいのでは?と気が付きました。
機構や構造が面白そうだったので、似たタイプのCセル2本用の中古の動作するマグライトを仕入れてテストしてみました。
リヤキャップのねじ込みはかなりシビアで、3mmほど緩めると点灯しなくなりました。
※マスキングテープの位置と点灯状態をご確認ください。
動く実機が手元にありますので、抵抗値や電圧など調べたいことがあればお知らせください。
Update 11/20
Have there been any further developments since then?
After giving it some more thought, one thing in particular caught my attention:
"It takes quite a bit of pressure to screw the rear cap onto the tube."
This made me wonder whether the threads might be damaged and preventing the cap from fully tightening, or perhaps there is some corrosion causing poor electrical contact. In either case, the connection between points C and E may not be reliable.
The mechanism and construction seemed interesting, so I obtained a working used Maglite of a similar design (using two C cells) and ran a few tests.
I found that the rear cap engagement is quite critical. Loosening the cap by about 3 mm was enough to cause the light to stop working.
Please check the position of the masking tape and the illumination status shown in the photos.
Since I now have a working unit on hand, let me know if there are any measurements you would like me to take, such as resistance values, voltages, or anything else.
[ This message was translated with AI assistance. ]
이미지
이미지
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
実機を入手できたので、画像と回答を修正いたしました。
의 공유
MuraMura: not much in further developments; it still doesn't work.
The pressure to screw E into C is because of the Spring.
With batteries removed, the threads are good: E screws Easily into the Tube.
Looks like there is no corrosion anywhere.
I see how you lined up the masking tape. Nice.
I even removed the rubber gasket from between E and the nearby threads.
The end cap Does Tightly screw into the Tube.
Sorry, people; I'm new here.
There's apparently a difference between a Comment and an Answer. OK.
And I got in trouble when I last replied "Was this answer helpful? No"
Trying here to Not reject the Author, just: the problem ain't Fixed.
I also wire-wheeled the blue paint off of the threads in front of E.
And from the threads inside the Tube.
Plain aluminum. No improvement.
Please watch a short video, and then please explain it.
Cannot now see how to add a short Video to THIS Location in the thread.
OK, It's added up at the top. OK.
THANKS for the continuing conversation.
의 공유
なかなか手ごわいですね・・!
動画を拝見しました。わかりやすい例示、ありがとうございます。
本体側は大丈夫で、あとはスイッチ、バッテリー、電球のいずれかですね。
一応念のため、バルブの写真を撮りましたので、写真4,5枚目に追加しておきます。
MAG 2cellの刻印があり、点灯時の電流値は700mAもありました。結構大食いです。
バルブ単体で、電池につないで光ればスイッチが原因。 光らなければ、バルブか電池がおかしいのかと思います。
This one is quite a tough case...!
I watched the video. Thank you for the clear demonstration; it was very helpful.
It looks like the flashlight body itself is fine, so the issue is likely one of three things: the switch, the battery, or the bulb.
Just to be sure, I took some photos of the bulb and added them as photos #4 and #5.
The bulb is marked "MAG 2cell", and I measured the current draw at approximately 700 mA when illuminated. It is actually quite power-hungry.
A simple test would be to connect the bulb directly to the battery:
If the bulb lights up, the switch is likely the problem.
If the bulb does not light up, then either the bulb itself or the battery is faulty.
That's my current thinking.
의 공유
댓글 달기
답변을 추가하세요
Mark578 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 52
지난 30일: 236
전체 시간: 236
