Starting problem with log splitter
TroubleshootIng a failure to start for PowerHorse log splitter
좋은 질문입니까?
좋은 질문입니까?
What have you checked so far? Does the engine turn over when you pull the starter cord, or is it completely unresponsive?
Start with the basics: check the fuel level, make sure the engine switch is ON, and confirm the choke is set correctly for a cold start. Also check whether the spark plug wire is connected securely.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 11
지난 30일: 26
전체 시간: 26
@dave83837 what model is your log splitter and what engine does it have (if you know)? Exactly what does your engine do when you try to start it?
oldturkey03 의 공유
@dave83837 To add on, we are not mind readers, and we certainly are not in your cameras. We need the exact information, excluding anything private, such as the Serial number.
Theo Grefalda 의 공유
Is your log splitter gas or electric?
F Dryer 의 공유
