주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
전자레인지에 대한 수리 가이드 및 문제해결 정보입니다.
Micro wave not heating up
Can you repair a micro wave
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@roberthousden No, because the "I" in iFixit means YOU! We teach you how to fix your stuff.
Now, what is the Microwave that we are working with? Make and model? We need some information here before we throw out a answer to you.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
The short answer here is that yes, a microwave oven can be repaired in most cases.
As Theo already stated, we can't do anything without knowing which microwave you have, as repair and troubleshooting procedures will vary widely among different models and manufacturers.
Failing to heat can be caused by any number of problems, so diagnostic steps would need to be taken to determine what failed. Are you comfortable using a multimeter? Can you safely discharge the high voltage capacitor inside the oven? Are you knowledgeable about safety procedures for high voltage circuits?
If you answered no to any of these questions, you'll be better off taking it to a repair shop than trying to work on it yourself. There are potentially lethal voltages present inside so precautions must be taken in order to safely work on it.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Robert Housden 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 35
전체 시간: 35
