Oil Pan plastic fastener
좋은 질문입니까?
Its a fastener, usually used to secure tubing or wiring. They do have a habit of breaking off when you try to remove them, and that looks like what you're seeing. There's probably a wire or some kind of tubing nearby that's supposed to be attached to it. The other half of it will either be a T shape that's held on with some sort of wrap like electrical tape or else it'll have a zip tie to secure the wire or tube.
Here are a couple of pictures of the fasteners I'm talking about.
이 답변이 도움이 되었나요?
Thank you. Do you know the part number ? I couldn’t find it online. I wanna put the pan back in place.
I wouldn't put a lot of time into finding an exact replacement. In your case I'd just pry the old plastic out then just use a zip tie looped into the opening to fasten back whatever is supposed to be attached there.
지난 24시간: 1
지난 7일: 2
지난 30일: 28
전체 시간: 28
