이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
If you shine a light on the screen do you see picture or nothing at all? If you see picture it is a backlight issue, if nothing is visible then it is a display issue…
@talhatariq97866 connect an external monitor and see if that displays properly. If so then it is an issues withing your LCD. Like already suggested, it could be a bad backlight etc.
If the external monitor also does not display then it could be an issues with your motherboard or the BIOS. It is possible that your computer does not properly post. Let us know what you find out.
honakrisi 의 공유
oldturkey03 의 공유
