주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yamaha P-125는 뛰어난 피아노 성능과 사용자 친화적인 미니멀리즘 디자인이 결합된 컴팩트한 디지털 피아노입니다. 휴대가 간편하고 사용하기 매우 쉬워 언제 어디서든 피아노 연주의 즐거움을 경험할 수 있습니다.
ghost press on the rythm button
So i bought this used P-125a and occasionally the rythm would activate itself. But today it got so bad that everytime I turn on the keyboard the rythm would activate, it's still running as I write this, I tried holding down the metronome button without the rythm and it activated function since holding rythm+metronome does that, so it leads me to think that rythm is being continuously pressed down, in one instance function was activated without pressing down anything leading me to suspect that metronome button could also have the same problem. The piano was mostly clean on purchase save for this volume slider which has collected dust.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
My guess is that the tactile switch underneath the button is leaking or contaminated, causing intermittent false button presses.
If you'd like to try something before taking it apart, press the affected button about 100 times. In some cases, this can restore normal operation. However, disassembling the unit and repairing or replacing the switch is the most reliable fix.
The Yamaha P-125 service manual can also be downloaded from sites such as Elektrotanya.
https://elektrotanya.com/yamaha_p-125b_w...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello there, so about 2 hours before you published your comment i was trying to practice and it kept turning on and i crashed out and started slamming the button aggressively like 25 times then tuned of the piano, and that actually fixed it😭😭😭.
I have been playing since yesterday and so far there has only been 1 very brief instant of the ghost press otherwise it has been working fine.
Also i was trying to find that service manual but couldn't find it, thanks for the link.
의 공유
댓글 달기
답변을 추가하세요
sadique arman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 36
지난 30일: 36
전체 시간: 36
