주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
꽤 오랜 기간 사용한 R407 가스 방식의 벽걸이형 에어컨
Ac indoor display e1 error
My ac indoor display e1 error what happened is there any operation mistake or what how can repair
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I asked FixBot your question and its reply is in italics. FixBot AI can make mistakes. Verify critical details from reliable sources.
I [FixBot] couldn't find a specific troubleshooting guide for this exact error in iFixit's knowledge base, but information found elsewhere on the web indicates that an E1 error code on a split air conditioner typically points to one of a few common issues:
  • Temperature Sensor (Thermistor) Failure: The indoor room temperature sensor is disconnected, shorted, or faulty, preventing the control board from reading the ambient temperature.
  • Communication Fault: A loose, corroded, or damaged wiring connection between the indoor and outdoor units.
  • Control Board / Button Glitch: A temporary electronic latch or stuck button on the display panel requiring a system reset.
To troubleshoot, try cutting power to the air conditioner at the circuit breaker for 5 to 10 minutes to allow the control board to fully reset. If the error immediately returns, inspect the indoor unit's wiring connections and temperature sensor near the evaporator coil.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Suryakant Macwan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 18
전체 시간: 18
