주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 5월 14일에 출시된 Google Pixel 8a 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GKV4X(5G Sub 6GHz) 및 G8HHN(5G mmWave + Sub 6GHz)으로 식별할 수 있습니다.
Below screen graphite sheet
Hello,
I was in the process of removing my very cracked Pixel 8a screen and in the process the graphite thermal sheet that is adhered to the midframe and is located directly under the display got messed up. I was hoping there was a replacement listed on ifixit but there seems to be nothing available and even the bill of materials and Google's own repair documentation don't mention a specific replacement part or anything for this.
Does anybody know if there is a replacement sheet specifically for the Pixel 8a or would this have to be something I have to order a sheet and then cut it myself? See pic, the red outlined stuff is what I'm looking for:
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@thomas787524, if I'm not mistaken, the picture you used to illustrate the graphite sheet is taken from the screen replacement guide, is that right?
Could you post a picture of your sheet? Maybe it's not as bad as you think; if we can see what you're looking at we can help judge if it's usable or not. It's not vital that it cover 100% of the original area.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
I didn't have any more luck locating the graphite sheet you're looking for, but I did note that it appears at least one replacement midframe comes with the graphite sheet already attached. Here's a picture showing it.
이미지
Of course, you'd need to order one in the right color for your phone; some of them on that site are reasonable (under $25 USD), but a couple are quite a bit more pricey; on the order of $60. Anyway, here's the page; hopefully yours is one of the cheap ones!
Google Pixel 8a Replacement Parts – SOULTZ PHONE PARTS
If you do a search for "google Pixel 8a midframe replacement" you'll find a few choices; the one I linked to appears to be an aftermarket replacement. It seems the genuine Google midframes don't come with the graphite sheet. Another option might be to purchase a system pull; i.e., one from a phone that's been parted out; that'll save you some effort on the replacement since it comes with many of the small parts already attached. Here's an example from eBay (again, I don't know what color yours is, so I can't tell if it's the right one for you or not).
Repair Part - OEM Pull Frame with Small Parts for Google Pixel 8A - Obsidian - eBay
You can see from the second picture on the site that the graphite sheet is there and intact, so that might be another option. I'd go with one of those first before trying to make one myself, especially with that oddball little flap that goes over the screen connector.
Good luck, and be sure to come on back and let us know how it all turns out; what you learn will help the next person who comes along with the same problem.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 23
전체 시간: 23
