주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Biometric fingerprint needs Calibration
I need my phones biometrics fingerprint re calibrated
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
A "fingerprint sensor calibration needed" error on a S24 FE usually happens after a software update, screen replacement, or when the sensor configuration loses sync.
Quick Fixes to Try First
  • Restart and clean: Restart your phone and wipe the screen over the fingerprint sensor and your fingertips so they are clean and dry.
  • Turn on Touch sensitivity: If you use a screen protector or tempered glass, go to Settings > Display and enable Touch sensitivity.
  • Re-register fingerprints: Remove existing prints under Settings > Security and privacy > Biometrics > Fingerprints, then add them again slowly—including the edges of your fingertip.
  • Use "Improve accuracy": Open your registered fingerprint in settings, tap Improve accuracy, and scan the same finger 10 times.
Reset Settings or Get Hardware Calibration
  • Reset settings: If a glitch or update caused the message, a guide on Samsung Fingerprint Sensor Not Working notes that resetting accessibility or device settings can clear the prompt after a software sync issue.
  • Repair or service center calibration: As explained in Fix: Fingerprint Sensor Not Working in Samsung After Screen Replacement, replacing a display or having a faulty sensor often requires official calibration or service tools. If the screen was recently repaired or the error stays, contact Samsung Support or an authorized repair shop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
MILLET CTS 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 56
전체 시간: 56
