6세대 Ford Fiesta(2008–2017)는 유럽에서는 MK6, 영국 및 북미에서는 MK7으로 자주 불립니다. 엔진 라인업에는 1.25L Duratec과 1.0L 3기통 EcoBoost 터보가 포함되었습니다. 성능 애호가를 위한 ST 트림은 182마력을 내는 강력한 1.6L EcoBoost 엔진을 탑재했으며, 장거리 운전자는 1.5L 또는 1.6L TDCi 디젤 모델을 선택했습니다.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Vehicle ac repairs are not diy friendly. All ac systems are sealed at factory assembly because refrigerant is under pressure at all times like spray paint cans. 98% of ac problems are leaks no one wants to find but run to stores for refill kits, refilling or topping off....a leaking system. Sealer is never used at factory assembly because it will ruin a system. Sealer used in refill kits will ruin a system with repair costs higher than if a leak was found and repaired. Service valves may leak if caps aren't tightened. 9+ years can be considered as wear and tear when a leak occurs, compressor clutch coil fails, air gap opens preventing clutch engagement, etc. A can of leak detector (no sealer) and an inexpensive uv black light can find dye leaking out from; compressor front seal, fittings, aluminum parts.
F Dryer 의 공유
