주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
다양한 Canon 디지털 및 필름 카메라를 위한 수리 및 분해 가이드입니다.
SD Card lock error
I am teaching photography in high school. I have a class set of G7X Mark III cameras. This year 6 (so far) are giving me the error saying the SD card is locked. The cards are not locked. I have tried with multiple card brands and storage.
I suspect students are shoving the cards in the wrong way which is damaging whatever sensor there is for the lock. It is way too expensive to get them looked at for repair, and I cant just replace this many so often. Help please.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try different cards first or buy a new test card you only use to see if the camera is damaged - SD cards are kind of delicate and with high school kids who treat laptops as toys? They don't last and should be treated as a consumable. If they damaged the sensor on the slot which is very hard to do because you can't jam it in very easily, it often requires a whole logic board and sensor cal with Canon unless you can solder a new SD card reader on the PCB. I would look into the SD cards first.
What I would consider as a teacher (and this is coming from someone who had mentors who were more then sloppy teachers, so it's not canned) -- you supply the cameras, student supplies the SD card. You do not demand SanDisk, PNY or Kingston but you let them know Canon cameras usually work best with OWC/MacSales and SanDisk cards. PNY works, but PNY consumer flash outside of SSDs is throttling garbage that is low grade junk - they buy based on spot, whereas SanDisk makes their own flash and OWC uses good Tier 1 flash. Another one I like is Lexar, but you want the pro grade cards - used to be a fab owner under Micron but their SD cards are top notch. Lexar quit making consumer media a few years ago, and good riddance - we need fewer junk consumer grade cards. If you get a student who geninely can't afford to buy a SD card, keep a few SanDisk Ultras around - they're not Extreme/Extreme Pro good, but they're reliable.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Caen N 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 33
