주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Craftsman 가스식 제설기 536.881800은 진입로, 보도, 주차장에서 눈을 치우기 위해 설계된 가솔린 연료 구동 기기입니다. 이 페이지에서는 다양한 엔진 배기량 모델(148 cc, 206 cc, 305 cc, 342 cc)로 출시된 이 제설기에 대한 자세한 정보와 수리 지침을 제공합니다.
when handle is engaged
When I first go to engage the drive, it will start to move and then stop
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@harveyharders Does the engine disengage when the snow blower stops?
의 공유
댓글 달기
답변 1개
가장 유용한 답변
I asked FixBot (Ai) your question with its reply in italics. Beware of Ai mistakes. I'm not 100% familiar with motorized snowblowers but if I had to try servicing one, I'd review owner's manuals and get hands dirty looking for adjustments, slippage, belt wear, etc, as a diyer. Scraped knuckles included.
"When I first go to engage the drive, it will start to move and then stop"
When a snow blower starts to move and then stops or slips when you engage the drive, it typically points to one of three common issues: a loose or worn traction drive belt, improper traction drive cable tension, or oil, grease, or wear on the rubber friction wheel and disc drive plate 1.
Here is what to check:
  • Traction Drive Cable: If the cable is stretched or out of adjustment, the drive spring may not maintain correct tension (should be 3 to 3-3/8 inches when depressed) 2.
  • Friction Wheel & Disc Plate: If grease or oil gets onto the rubber friction wheel or disc drive plate, it will grip momentarily and then slip as pressure increases. Ensure both surfaces are completely clean and free of lubricants 3. Inspect the rubber ring for wear or damage 4.
  • Traction Drive Belt: Check for wear, cracking, or looseness 5.
You can find the complete adjustment and troubleshooting procedures in the owner's manual here:
File
Craftsman 536.881800 Owners Manual
•Page 34•100 pages•5.8 MB
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Harvey Harders 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 24
지난 30일: 24
전체 시간: 24
