주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2025년 10월에 출시된 M5 칩 탑재 14형 MacBook Pro의 수리 안내서, 분해 정보, 문제해결 정보를 확인하세요. 모델 번호 A3434로 식별됩니다.
Irremovable Marks on Screen
이미지
이미지
Hello, I've been using a 14" Macbook Pro for a little over six months now, and I've noticed some marks on my display that, no matter how much I try to clean off, look to be permanent. I've used "Whoosh!" screen cleaner and 70% isopropyl alcohol, but there's always some marks left, sometimes even visible at high brightness. I think it's worth mentioning I sometimes use my laptop closed for long periods of time, potentially exposing the display to higher than average temperatures. Although I've heard that this is safe, I feel that this could have contributed to this. Has anyone else experienced this? How can I get rid of them and prevent them from re-appearing or getting worse? Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
hmm could be the antireflective coating wearing off because of the heat somehow although its unlikely. It could ofc also be the keyboard leaving imprints on the screen but we'll need pictures to confirm : 기존 질문에 이미지 추가하기
의 공유
A photo taken at an angle with the screen off and a bright light reflecting across it would help a lot here. If the marks line up with the key rows, it is usually contact imprinting rather than heat, and a thin microfiber sheet between keyboard and screen when closed can stop it getting worse. Since it is only six months old, it may also be worth asking Apple to look at the coating before trying anything more abrasive.
의 공유
@leooooo1061 I've attached a couple images to the post. The keyboard imprint as well as some marks outlining the trackpad are definitely visible under a light.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@shawnlee95891 - I do find the newer models (2016 onward) tend to get rub marks from the keys, mostly when using a backpack that has stuff pressing on the lid directly.
I use a clean thin micro-cloth which fits over the keys preventing the keys from hitting to prevent that.
As far as damage running in clamshell mode the 2016 ~ 2019 systems tend to run hot with the Intel CPU's which did damage the T-CON logic from heat buildup. Since the M1 and newer M Series chips the heat issue has not been a problem and Apple did redesign the system to prevent the T-CON heat issue. So I wouldn't worry about that.
Update (11/25/26)
@shawnlee95891 - Sadly, you are facing key rubbing onto the screen
For now just use a micro-cloth dampened with kitchen spray cleaner to wipe down the keys and trackpad, don't spray the system! And use a good screen cleaner on the display to reduce the risk as well as making sure you aren't resting anything on the lid.
You might find a glass screen protector can improve things a bit as optical adhesive can fill-in some of the imperfections. I did that on my system as I wanted a matte finish to cut the glare. You do give up a little bit of the sharpness. The other choice is narrow-view which is a special polarizer to remove people looking over your shoulder to see the image on the display.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Shawn Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 25
지난 7일: 44
지난 30일: 44
전체 시간: 44
