Battery replacement FLIP 4 challenges.
My battery was NOT coming out! I tried prying from the lead wire end, tugging on the wires, etc. What I wound up doing: removed the opposite end cap, took 4 screws out of the USB port assembly to slide it out a little (I could not remove it entirely). This made room to insert a blunt push tool (AKA, an eraser-less drawing pencil's blunt end) in through the end, past the now-moveable USB port, and put that against the bottom of the battery to push it out from the bottom.
It was still not moving. I turned the speaker to the vertical position with the pencil on the workbench, battery lead lead end towed the ceiling. I raised the whole thing up a couple of inches off the bench and rapped it repeatedly so that the penci "tapped" (pretty hard) the battery out of the housing, a bit at a time. I had to persist and be pretty aggressive. It looked like a combination of sticky foam installation tape and swelling got it really stuck.
Also, the end caps (mine had the newer twist-to-release attachment, not the Phillips screws) were really tough to get to turn and there is not much to grab. I used a pair of large channel lock pliers (gently) and was able to get a grip and give them that slight counterclockwise turn to get them off.
Slowly, slowly. All is working well now.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
