7mm 펜 맨드릴 샤프트
답변 4개 6 점 |
Why won't my battery charge? |
답변 6개 3 점 |
Dremel 4000 quit working |
답변 5개 2 점 |
Black and Decker 20 volt Battery wont charge |
답변 5개 3 점 |
release the chuck with stuck drill bit |
부품
- FixHub Power Station Replacement Main Board Support
- FixHub Soldering Iron Replacement Power Switch Cover
- FixHub Soldering Iron Replacement End Cap
- FixHub Soldering Iron Replacement Enclosure
- FixHub Soldering Iron Replacement Grip
- FixHub Power Station Replacement Button
- FixHub Power Station Replacement Battery Cover
- FixHub Power Station Replacement Tool Mount
도구
- FixHub Soldering Iron Point Tip
- FixHub Soldering Iron Heat Insert Tip
- iFixit Safety Glasses
- FixHub Soldering Iron Knife 1.4 Tip
- FixHub Soldering Iron Wedge 1.5 Tip
- FixHub Soldering Iron Angle Cone Tip
- Cut-Resistant ESD Gloves
- FixHub Soldering Iron Wedge 4.0 Tip
- FixHub Soldering Iron Cone Tip
- FixHub Soldering Iron Bevel 2.6 Tip
- FixHub Soldering Iron Bevel 1.5 Tip
- FixHub Soldering Iron Angle Knife Tip
- FixHub Soldering Iron Knife 2.5 Tip
- FixHub Soldering Iron Bent Cone Tip
- FixHub Soldering Iron Bevel Cup 1.5 Tip
- FixHub Soldering Iron Bevel Cup 2.6 Tip
모델
AS52500468, AS5250BZ853, AS5517-5068, AS55527803, AS57336600, AS5733Z4477, AS57506438, AS57506636, AS7551G7606, CGRAXM230U, GP1, GRAS760U, GRAX230U, GRAX7600, GRAX760U, GRAX760US, GRAX761U, GRAX76U, GRAX880US, GRAX970U 43개 더 보기
GRAXAM230U, GRAXM151US, GRAXM2300, GRAXM230U, GRAXM231U, GRAXM23OU, GRAXM240U, GRAXM241U, GRAXM341U, GRCVL510U, GRD200U, GRD200US, GRD201US, GRD22US, GRD30US, GRD31US, GRD70US, GRD90US, GRD91US, GRD9OUS, GRDL815U, GRDLV310U, GRDM70U, GRDV500U, GRDV500US, GRDV800US, GRDVL500U, GRDVL500US, GRDVM76U, GRDX300US, GRDX75US, GRDX95US, GRSXM240, GRSXM240U, GRSXM245U, GRSXM340U, GRSXM540U, GRSXM740U, GRSXM745U, GRSXM750US, LXSA9020, PANORAMA, PV1D
배경
전동 공구는 건설, 수리 및 유지보수 작업에 수반되는 육체노동을 덜어주는 다양한 기능을 제공하며, 전문적인 작업과 DIY 프로젝트 모두에서 필수적입니다. 이러한 공구는 DeWalt, Milwaukee, Makita와 같은 유명 브랜드를 포함한 다양한 제조사에서 생산됩니다.
역사적으로 이러한 브랜드들은 합병, 인수 및 기술 발전을 통해 내구성이 뛰어나고 효율적인 공구를 제공해 왔습니다. 예를 들어, Milwaukee는 REDLITHIUM 배터리 기술로 잘 알려져 있습니다.
전동 공구 제조는 종종 전 세계 여러 지역에서 이루어지며, 중국, 독일, 일본 및 미국과 같은 국가들이 주요 생산 시설을 보유하고 있습니다.
식별
전동 공구를 식별하려면 일반적으로 모델 번호를 찾아야 하는데, 이는 대개 공구에 부착된 라벨에 있거나 공구 외관에 각인되어 있습니다. DeWalt의 인기 모델로는 DCD771(전동 드릴)과 DCF885(임팩트 드라이버)가 있으며, Milwaukee의 인기 모델로는 2804-20(해머 드릴)과 2853-20(임팩트 드라이버)이 있습니다.
브랜드마다 서로를 구분 짓는 고유한 색상 구성과 디자인 특징이 있는 경우가 많습니다. 예를 들면 다음과 같습니다:
- DeWalt: 노란색과 검은색 조합.
- Milwaukee: 빨간색과 검은색 조합.
- Makita: 청록색과 검은색 조합.
- Ryobi: 연두색과 검은색 조합.
모델 번호는 정확한 수리 정보와 교체 부품을 구하는 데 중요합니다. 모델 번호를 찾기 쉬운 곳으로는 배터리함 근처, 모터 하우징 또는 공구 손잡이 등이 있습니다.
문제해결
전동 공구에서 흔히 발생하는 문제로는 배터리 문제, 모터 오작동 및 기계적인 마모 등이 있습니다. 배터리 관련 문제의 경우, 배터리가 완전히 충전되어 있고 올바르게 장착되었는지 확인하는 것이 중요합니다. 모터 문제는 브러시와 전기 연결부를 점검해야 할 수 있습니다. 기계적인 문제는 대개 기어, 베어링 및 기타 회전 부품의 마모, 윤활 상태, 정렬 상태를 점검해야 합니다.
지속적인 유지보수를 통해 전동 공구와 관련된 많은 공통적인 문제를 해결하거나 예방할 수 있습니다.
