주요 콘텐츠로 건너뛰기
1995-2001 Honda CRV Radio Replacement
Adam Huth
Adam Huth7 다른 기여자
최종 수정일 January 4, 2021
40 분 - 2 시간
어려움
액션 샷
If your radio has stopped working or you are looking to upgrade your factory radio, you can use this guide to remove the factory radio from your 1995-2001 Honda CRV. Follow these steps to remove the radio.
필요한 것
도구
  1. 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: 1 단계, 이미지 3개 중 1개 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: 1 단계, 이미지 3개 중 2개 1995-2001 Honda CRV Radio Replacement, 1995-2001 Honda CRV Radio Replacement: 1 단계, 이미지 3개 중 3개
    • Remove the clips in the glovebox by pushing them in.
    • Using a Phillips #0 screwdriver, remove one screw on left side of the glovebox frame and one screw on the right side of the glove box.
  2. 1995-2001 Honda CRV Radio Replacement: 2 단계, 이미지 3개 중 1개 1995-2001 Honda CRV Radio Replacement: 2 단계, 이미지 3개 중 2개 1995-2001 Honda CRV Radio Replacement: 2 단계, 이미지 3개 중 3개
    • Use your hands to open the fold-down pocket.
    • Use a Philips #0 screwdriver to remove the four screws surrounding the fold-down pocket.
    • Use the Phillips #0 to remove the final screw from the fold-down pocket.
  3. 1995-2001 Honda CRV Radio Replacement: 3 단계, 이미지 2개 중 1개 1995-2001 Honda CRV Radio Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic panel tool to remove the plastic clip from the left side of the trim panel below the fold down pocket.
    • Use the same panel tool to remove the plastic clip from the right side of the trim panel below the fold down pocket.
  4. 1995-2001 Honda CRV Radio Replacement: 4 단계, 이미지 2개 중 1개 1995-2001 Honda CRV Radio Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the two screws from the driver-side dashboard.
    • Use a plastic panel tool to unclip the edges of the dashboard.
  5. 1995-2001 Honda CRV Radio Replacement: 5 단계, 이미지 2개 중 1개 1995-2001 Honda CRV Radio Replacement: 5 단계, 이미지 2개 중 2개
    • Use your hands to pull off the center dash.
    • Remove the 13mm screws connecting the console to the frame.
  6. 1995-2001 Honda CRV Radio Replacement: 6 단계, 이미지 1개 중 1개
    • Use your hand to unplug the cigarette lighter and A/C Controls.
    • Use caution to avoid damaging the wires.
  7. 1995-2001 Honda CRV Radio Replacement: 7 단계, 이미지 2개 중 1개 1995-2001 Honda CRV Radio Replacement: 7 단계, 이미지 2개 중 2개
    • Use your hands to gently remove the radio bezel.
    • Use your fingers to unclip the radio harness from the radio.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Adam Huth
회원 가입일: 01/17/17
305 평판
안내서 1개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 22개를 작성함
댓글 4개
I had a single DIN ALPINE stereo “professionally” installed in my late dad’s 2001 CRV. Two weeks after the install, it starts to rattle, had a broken aftermarket single DIN radio already installed, NEVER rattled! Now, I just discovered that if I put my hand in the tray under the new radio, the whole console piece with the radio and HVAC knobs just slides out! Did they forget the 13mm side screws that hold it in??? Or, damaged something else back there? Very upset!!! Any ideas??
savroof - 답글
After the removal you may need Honda radio code that will help you unlock your original radio (if you decide to use it). I had the same problem before a month. I solve it using the guide from this unlock Honda page: https://www.hondaradiocodebyvin.com/!
angelovblaze - 답글
Following the removal, you might require the Honda radio code to facilitate unlocking your original radio should you choose to reinstall it. I encountered a similar issue a month ago and successfully resolved it by referring to the instructions provided on this Honda unlocking page: CAR RADIO CODE UNLOCK SERVICE
gregory - 답글
After removing the radio, you might need the Honda radio code to unlock and use your original radio. I encountered the same issue a month ago and resolved it using the guide on this unlock Honda page: https://radiounlocked.com/
Mark Hamminer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 42
지난 30일: 151
전체 시간: 27,190
