주요 콘텐츠로 건너뛰기
2006 Iron Horse Warrior Chainring Replacement
Scott Kaufman
Scott Kaufman2 다른 기여자
최종 수정일 June 25, 2015
15 - 20 분
조정
This replacement involves removing the crank arm in order to access the chainring you are trying to replace.
  1. 2006 Iron Horse Warrior Chainring Replacement, Chainring: 1 단계, 이미지 1개 중 1개
    • Remove the cap covering the crank arm using the 6mm Allen Key
  2. 2006 Iron Horse Warrior Chainring Replacement: 2 단계, 이미지 2개 중 1개 2006 Iron Horse Warrior Chainring Replacement: 2 단계, 이미지 2개 중 2개
    • Screw the larger diameter threads on the crank puller into the hole you removed the cap from.
    • Slightly tighten it with an adjustable wrench.
  3. 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 3개 중 1개 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 3개 중 2개 2006 Iron Horse Warrior Chainring Replacement: 3 단계, 이미지 3개 중 3개
    • Tighten the handle on the crank puller until the arm and gears slide off of the axle.
    • The crank puller works by locking into the threads on the arm and pushing against the Isis drive axle to pry the arm and gears off. Make sure you are using the correct size crank puller, otherwise this step will not work.
    • During reassembly, add some grease to the axle to make it easier to remove the arm in the future.
  4. 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 3개 중 1개 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 3개 중 2개 2006 Iron Horse Warrior Chainring Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the four 6mm hex bolts from the small chainring using the 6mm hex screwdriver. This will allow you to remove the chainring.
    • When reinstalling, apply a loctite thread compound on the threads to keep them from loosening as you ride. Also, make sure the writing on the new chainring faces the frame of the bike.
    • This chainring has a bolt circle diameter of 64 mm (BCD 64) and 22 teeth; however, you can replace it with any chainring with a BCD of 64.
결론
작성자
2다른 기여자 명과 함께
Scott Kaufman
회원 가입일: 04/20/15
619 평판
안내서 3개를 작성함
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G2
4 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 844
