주요 콘텐츠로 건너뛰기
2012 Nissan Murano Driver Side Mirror Replacement
Gajtguy
Gajtguy3 다른 기여자
최종 수정일 July 12, 2017
45 분
쉬움
액션 샷
더 나은 이미지가 필요함
커뮤니티-기여 안내서
Full replacement of a Driver side mirror on a 2012 Nissan Murano, SL options package.
  1. 2012 Nissan Murano Driver Side Mirror Replacement, 2012 Nissan Murano Driver Side Mirror: 1 단계, 이미지 1개 중 1개
    • Pull out the Driver preset panel, if your options package included this. Usually no tools required.
  2. 2012 Nissan Murano Driver Side Mirror Replacement: 2 단계, 이미지 1개 중 1개
    • Expose one of three screws by prying the door handle trim plate out.
  3. 2012 Nissan Murano Driver Side Mirror Replacement: 3 단계, 이미지 3개 중 1개 2012 Nissan Murano Driver Side Mirror Replacement: 3 단계, 이미지 3개 중 2개 2012 Nissan Murano Driver Side Mirror Replacement: 3 단계, 이미지 3개 중 3개
    • Pry out the door lock and window control panel. Disconnect all connectors on the back side.
  4. 2012 Nissan Murano Driver Side Mirror Replacement: 4 단계, 이미지 1개 중 1개
    • Pry up the arm rest to expose the second hidden screw (total of 3).
  5. 2012 Nissan Murano Driver Side Mirror Replacement: 5 단계, 이미지 1개 중 1개
    • Now you can remove all three hidden screws with the 10mm socket or philips screw driver.
    • Now the door panel itself can be pried off the door. Starting at the bottom, find the plastic friction plugs and pull enough to pop them out one by one.
    • Then lift the door panel up off the door. You do not need to remove it completly. This should give you enough room to work on the mirror in the next steps.
  6. 2012 Nissan Murano Driver Side Mirror Replacement: 7 단계, 이미지 2개 중 1개 2012 Nissan Murano Driver Side Mirror Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the inside mirror cover off.
  7. 2012 Nissan Murano Driver Side Mirror Replacement: 8 단계, 이미지 1개 중 1개
    • Unplug the mirror wiring harness. The connector on the door will stay put.
  8. 2012 Nissan Murano Driver Side Mirror Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the three nuts holding the mirror on to the door. Depending on the age of your vehicle, you may want to clean off the remaining area so the new mirror seals good.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Gajtguy
회원 가입일: 12/15/13
177 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 6,991
