주요 콘텐츠로 건너뛰기
2016 Nissan Altima Door Courtesy Lamp Replacement
Jay Michalek
Jay Michalek2 다른 기여자
최종 수정일 June 1, 2023
25 분
쉬움
추천 학생 안내서
If the courtesy door lamp on your 2016 Nissan Altima is no longer lighting up due to a burnt out bulb or other damages to lamp housing, use this guide to replace it.
The door courtesy step lamp produces a light near the ground while the car door is open. The light produced is useful for seeing where a driver and/or passenger will step while entering or exiting the vehicle in the dark. Not only is a non functioning door lamp visually unappealing, but could be dangerous if you misstep and fall in the dark.
This guide describes how to replace the courtesy lamp housing/light bulb combination. If your courtesy lamp is not producing light due to faulty wiring, spark plugs, or other reasons not caused by the light itself, this guide will not fix your issue.
Before starting this guide, make sure you turn off your vehicle to disconnect the power going to the courtesy lamp. Place the car in park and engage the parking brake.
  1. 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: 1 단계, 이미지 2개 중 1개 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: 1 단계, 이미지 2개 중 2개
    • Open the door with the faulty courtesy lamp.
    • The courtesy lamp should be located on the bottom of the door.
  2. 2016 Nissan Altima Door Courtesy Lamp Replacement: 2 단계, 이미지 2개 중 1개 2016 Nissan Altima Door Courtesy Lamp Replacement: 2 단계, 이미지 2개 중 2개
    • Gently pry the lamp housing away from the door using a ESD-safe pry tool.
  3. 2016 Nissan Altima Door Courtesy Lamp Replacement: 3 단계, 이미지 1개 중 1개
    • Press down on the white release tab at the far left end of the lamp housing.
  4. 2016 Nissan Altima Door Courtesy Lamp Replacement: 4 단계, 이미지 2개 중 1개 2016 Nissan Altima Door Courtesy Lamp Replacement: 4 단계, 이미지 2개 중 2개
    • Pull back on the release tab as you press down to separate the lamp housing from the door wiring.
  5. 2016 Nissan Altima Door Courtesy Lamp Replacement: 5 단계, 이미지 1개 중 1개
    • Reinsert the wire plug back into the lamp housing.
    • Gently push on the plug until you can no longer insert it further.
    • You should hear an audible click once you've inserted the plug all the way.
  6. 2016 Nissan Altima Door Courtesy Lamp Replacement: 6 단계, 이미지 1개 중 1개
    • Turn on the vehicle to verify that the new light works.
    • Look at the bulb to verify that it lights up.
    • You may have to close and re-open the door in order for the light to turn on.
    • There is a chance of electric shock if the wires to your courtesy light are faulty. Avoid touching the light bulb or wires directly.
  7. 2016 Nissan Altima Door Courtesy Lamp Replacement: 7 단계, 이미지 1개 중 1개
    • Insert the bottom latches of the lamp into the door socket.
    • Push the top of the lamp into the socket so that the lamp housing is flush with the car door.
    • Reinserting the lamp may require more force than it appears.
결론
If you followed all of the steps correctly your courtesy door lamp should be replaced and functional!
작성자
2다른 기여자 명과 함께
Jay Michalek
회원 가입일: 02/23/23
145 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 43
전체 시간: 489
