주요 콘텐츠로 건너뛰기
3DS XL SD Card Cover Replacement
Ben
Ben2 다른 기여자
최종 수정일 September 14, 2024
10 - 15 분
쉬움
커뮤니티-기여 안내서
So you've got a new shell for your 3DS XL and want your SD cover to be the same color as your device? Follow this guide to have it done in 10 - 15 minutes, with minor disassembly.
  1. 3DS XL SD Card Cover Replacement, Remove back panel + battery: 1 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement, Remove back panel + battery: 1 단계, 이미지 2개 중 2개
    • If you have a stylus, SD card or a game cartridge in the console, take them out
  2. 3DS XL SD Card Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  3. 3DS XL SD Card Cover Replacement: 3 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  4. 3DS XL SD Card Cover Replacement: 4 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  5. 3DS XL SD Card Cover Replacement, Open the shell: 5 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement, Open the shell: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  6. 3DS XL SD Card Cover Replacement: 6 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  7. 3DS XL SD Card Cover Replacement, Detach top from bottom: 7 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement, Detach top from bottom: 7 단계, 이미지 2개 중 2개
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the upper case from the rest of the device and set aside.
  8. 3DS XL SD Card Cover Replacement, Replacing SD Cover: 8 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement, Replacing SD Cover: 8 단계, 이미지 2개 중 2개
    • Remove the 3 golden, 2.3 mm screws located around the stylus slot with a Phillips #00 screwdriver.
  9. 3DS XL SD Card Cover Replacement: 9 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement: 9 단계, 이미지 2개 중 2개
    • Using a pry tool, lift up the thin metal plate above the SD Card Cover.
  10. 3DS XL SD Card Cover Replacement: 10 단계, 이미지 2개 중 1개 3DS XL SD Card Cover Replacement: 10 단계, 이미지 2개 중 2개
    • Slightly bend the silicone (Light Gray) part and pull the cover out of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben
회원 가입일: 10/06/23
241 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 60
지난 30일: 237
전체 시간: 2,321
