주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4Sight 9 Charging Port Replacement
필요한 것
  1. 4Sight 9 Charging Port Replacement, Cover: 1 단계, 이미지 2개 중 1개 4Sight 9 Charging Port Replacement, Cover: 1 단계, 이미지 2개 중 2개
    • Place the tablet on its side so that the two screws are facing upward.
    • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
    댓글 쓰기
  2. 4Sight 9 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
    • Once loosened, use your hands to separate the case from the device.
    댓글 쓰기
  3. 4Sight 9 Charging Port Replacement: 3 단계, 이미지 2개 중 1개 4Sight 9 Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Hold the positive and negative wires as close as possible to the speaker.
    • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
    댓글 쓰기
  4. 4Sight 9 Charging Port Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    댓글 쓰기
  5. 4Sight 9 Charging Port Replacement: 5 단계, 이미지 2개 중 1개 4Sight 9 Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
    • Put pressure on the connector until the clasp comes undone.
    • Gently pull up on electrical ribbon until it disconnects from circuit board.
    댓글 쓰기
  6. 4Sight 9 Charging Port Replacement: 6 단계, 이미지 2개 중 1개 4Sight 9 Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the second electrical ribbon from the motherboard.
    • Use the technique for the previous ribbon.
    댓글 쓰기
  7. 4Sight 9 Charging Port Replacement: 7 단계, 이미지 1개 중 1개
    • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
    댓글 쓰기
  8. 4Sight 9 Charging Port Replacement: 8 단계, 이미지 2개 중 1개 4Sight 9 Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • With fingers, grip the green Wi-Fi connector.
    • Gently pull up on connector to remove tape holding the connector in place.
    댓글 쓰기
  9. 4Sight 9 Charging Port Replacement: 9 단계, 이미지 1개 중 1개
    • Using your fingers, gently lift the motherboard.
    댓글 쓰기
  10. 4Sight 9 Charging Port Replacement, Charging Port: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use soldering gun and when solder is malleable, lift up on the left side of the charge port until it is not connected to the board with tweezers.
    • Charging port may be very hot due to soldering iron.
    • Repeat this step on right side of charging port.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Robert Shredow
회원 가입일: 04/07/15
185 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 26
전체 시간: 1,564
