주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4Sight 9 Screen Replacement
필요한 것
    1. 4Sight 9 Screen Replacement, Cover: 1 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement, Cover: 1 단계, 이미지 2개 중 2개
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      댓글 쓰기
    2. 4Sight 9 Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      댓글 쓰기
    3. 4Sight 9 Screen Replacement: 3 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      댓글 쓰기
    1. 4Sight 9 Screen Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      댓글 쓰기
    2. 4Sight 9 Screen Replacement: 5 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      댓글 쓰기
    1. 4Sight 9 Screen Replacement, Screen: 6 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement, Screen: 6 단계, 이미지 2개 중 2개
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      댓글 쓰기
    2. 4Sight 9 Screen Replacement: 7 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the second electrical ribbon from the motherboard using the same technique used to remove first ribbon.
      댓글 쓰기
    3. 4Sight 9 Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      댓글 쓰기
    4. 4Sight 9 Screen Replacement: 9 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement: 9 단계, 이미지 2개 중 2개
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      댓글 쓰기
    5. 4Sight 9 Screen Replacement: 10 단계, 이미지 2개 중 1개 4Sight 9 Screen Replacement: 10 단계, 이미지 2개 중 2개
      • With the motherboard facing you, look to the bottom left corner, pull on the camera to completely free the motherboard.
      댓글 쓰기
    6. 4Sight 9 Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Using your fingers, gently lift the motherboard and battery.
      댓글 쓰기
    7. 4Sight 9 Screen Replacement: 12 단계, 이미지 3개 중 1개 4Sight 9 Screen Replacement: 12 단계, 이미지 3개 중 2개 4Sight 9 Screen Replacement: 12 단계, 이미지 3개 중 3개
      • Insert plastic prying tool under screen and exert pressure, pulling upward.
      • Repeat this step around each corner of the screen until it pops off.
      • Ensure screen is free from all black tabs holding it in place.
      댓글 쓰기
    8. 4Sight 9 Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes
      • Remove plastic film from glass frame
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Hali Ramirez
회원 가입일: 04/07/15
657 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 3,423
