주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
8BitDo Ultimate Wireless D-Pad Replacement
필요한 것
  1. 8BitDo Ultimate Wireless D-Pad Replacement, Case: 1 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    댓글 쓰기
  2. 8BitDo Ultimate Wireless D-Pad Replacement: 2 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    댓글 쓰기
  3. 8BitDo Ultimate Wireless D-Pad Replacement: 3 단계, 이미지 3개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement: 3 단계, 이미지 3개 중 2개 8BitDo Ultimate Wireless D-Pad Replacement: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    댓글 쓰기
  4. 8BitDo Ultimate Wireless D-Pad Replacement: 4 단계, 이미지 3개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement: 4 단계, 이미지 3개 중 2개 8BitDo Ultimate Wireless D-Pad Replacement: 4 단계, 이미지 3개 중 3개
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    댓글 쓰기
  5. 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: 5 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: 5 단계, 이미지 2개 중 2개
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell, then lift the board out.
    댓글 쓰기
  6. 8BitDo Ultimate Wireless D-Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully lift the D-pad conductive pad out of the shell.
    댓글 쓰기
  7. 8BitDo Ultimate Wireless D-Pad Replacement: 7 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless D-Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the directional pad.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alexander Garcia
회원 가입일: 04/03/26
473 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 회원
UMASSD-BISWOKARMA-S26S1G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 37
전체 시간: 99
