주요 콘텐츠로 건너뛰기
8Bitdo N30 Joystick Replacement
Carlie Kratz
Carlie Kratz10 다른 기여자
최종 수정일 June 22, 2022
15 - 25 분
조정
Use this guide to replace a faulty joystick component on the 8Bitdo N30 Arcade Stick without damaging the Retro game controller.
A Phillips #0 screwdriver and a flathead 3/32” screwdriver are required to remove screws.
No special skills are required. Take caution in regards to removing and organizing the pieces of the 8Bitdo N30 Joystick when you are replacing the joystick.
필요한 것
도구
  1. 8Bitdo N30 Joystick Replacement, Joystick: 1 단계, 이미지 2개 중 1개 8Bitdo N30 Joystick Replacement, Joystick: 1 단계, 이미지 2개 중 2개
    • Turn the device over so that the bottom of the device is facing up.
  2. 8Bitdo N30 Joystick Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove all ten of the 3 mm screws on the back plate.
  3. 8Bitdo N30 Joystick Replacement: 3 단계, 이미지 2개 중 1개 8Bitdo N30 Joystick Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the rubber slider from the device.
    • Hold the arcade stick and pry the back panel away from the device until it comes off.
    • Remember the position of the rubber slider; it will be replaced at the end of the process.
  4. 8Bitdo N30 Joystick Replacement: 4 단계, 이미지 2개 중 1개 8Bitdo N30 Joystick Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the back piece of the joystick.
    • Remove the four screws that secure the joystick using the Phillips #0 screwdriver.
  5. 8Bitdo N30 Joystick Replacement: 5 단계, 이미지 2개 중 1개 8Bitdo N30 Joystick Replacement: 5 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to remove the middle screw that holds the ball piece onto the joystick.
    • Remove the ball piece and set it aside.
    • Be sure to hold the ball piece in place while turning the screw counterclockwise.
    • When attaching the new joystick and ball piece, turn the screw clockwise while holding the ball piece in place.
  6. 8Bitdo N30 Joystick Replacement: 6 단계, 이미지 3개 중 1개 8Bitdo N30 Joystick Replacement: 6 단계, 이미지 3개 중 2개 8Bitdo N30 Joystick Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the joystick wires that are attached to the four plugs on the motherboard and disconnect them.
    • In fine print, "left," "down," "up," and "right" are found above the wires that need to be removed.
    • Take caution and gently disconnect the wires.
  7. 8Bitdo N30 Joystick Replacement: 7 단계, 이미지 2개 중 1개 8Bitdo N30 Joystick Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the back piece from the mounting plate.
    • Replace the joystick's back piece.
결론
Follow the steps in reverse order to install the new joystick.
Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Carlie Kratz
회원 가입일: 01/31/19
160 평판
안내서 1개를 작성함
댓글 한 개
looks just like the mayflash f300
Jon Hernandez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 29
전체 시간: 2,666
