주요 콘텐츠로 건너뛰기
ACER Aspire V5-571P-6609 RAM Replacement
Ernesto Pacheco
Ernesto Pacheco7 다른 기여자
최종 수정일 December 18, 2023
5 분
쉬움
This guide has complete step-by-step instructions to replace the RAM sticks in your ACER Aspire V5-571P-6609 laptop with proper precautionary measures. If you want to use larger applications, prevent the laptop from crashing, or have a better gaming experience, this guide is for you.
Remember to unplug the device and turn the laptop's power off while performing the RAM replacement. This can help prevent software corruption, data loss, and boot failure.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. ACER Aspire V5-571P-6609 RAM Replacement, RAM: 1 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement, RAM: 1 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 RAM Replacement, RAM: 1 단계, 이미지 3개 중 3개
    • Make sure you completely power off the device before proceeding.
    • Turn over the device to display the back cover and remove the two marked Phillips #0 screws.
  2. ACER Aspire V5-571P-6609 RAM Replacement: 2 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement: 2 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Once the screws have been removed, utilize a jimmy tool to pry open the back cover. Carefully lift the cover and set it aside for now.
  3. ACER Aspire V5-571P-6609 RAM Replacement: 3 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement: 3 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 RAM Replacement: 3 단계, 이미지 3개 중 3개
    • With two fingers, push the latches holding the DIMM to the sides.
    • The DIMM will tilt upward once it is released from the slot.
    • Carefully secure the DIMM and remove it.
  4. ACER Aspire V5-571P-6609 RAM Replacement: 4 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement: 4 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Repeat the same process from the previous step for the second slot.
  5. ACER Aspire V5-571P-6609 RAM Replacement: 5 단계, 이미지 2개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the replacement DIMM into the slot.
    • Once inserted, push the DIMM down gently until it snaps into place.
  6. ACER Aspire V5-571P-6609 RAM Replacement: 6 단계, 이미지 3개 중 1개 ACER Aspire V5-571P-6609 RAM Replacement: 6 단계, 이미지 3개 중 2개 ACER Aspire V5-571P-6609 RAM Replacement: 6 단계, 이미지 3개 중 3개
    • Place the cover back on.
    • Insert the screws back into place with a screwdriver.
결론
To reassemble your device, follow these instructions in reverse order with new RAM cards.
작성자
7다른 기여자 명과 함께
Ernesto Pacheco
회원 가입일: 10/25/22
277 평판
안내서 2개를 작성함
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022 회원
GCC-PEE-F22S1G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 31
전체 시간: 271
