주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APEX TM785CH Circuit Board Replacement
필요한 것
    1. APEX TM785CH Circuit Board Replacement, Back Casing: 1 단계, 이미지 2개 중 1개 APEX TM785CH Circuit Board Replacement, Back Casing: 1 단계, 이미지 2개 중 2개
      • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
      • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
      • Move along the top edge of the tablet and repeat the step above.
      • Pull the back cover away from the tablet body to completely remove it.
      댓글 쓰기
    1. APEX TM785CH Circuit Board Replacement, Battery: 2 단계, 이미지 2개 중 1개 APEX TM785CH Circuit Board Replacement, Battery: 2 단계, 이미지 2개 중 2개
      • With the back cover removed, you can now see the battery.
      • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
      댓글 쓰기
    1. APEX TM785CH Circuit Board Replacement, Microphone: 3 단계, 이미지 3개 중 1개 APEX TM785CH Circuit Board Replacement, Microphone: 3 단계, 이미지 3개 중 2개 APEX TM785CH Circuit Board Replacement, Microphone: 3 단계, 이미지 3개 중 3개
      • The microphone is located in the bottom center of the tablet.
      • Remove the black tape holding the wires down.
      • Remove the black tape holding the microphone in place.
      • The microphone is now exposed and can be gently pulled out of the socket.
      댓글 쓰기
    2. APEX TM785CH Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
      • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
      댓글 쓰기
    1. APEX TM785CH Circuit Board Replacement, Speakers: 5 단계, 이미지 3개 중 1개 APEX TM785CH Circuit Board Replacement, Speakers: 5 단계, 이미지 3개 중 2개 APEX TM785CH Circuit Board Replacement, Speakers: 5 단계, 이미지 3개 중 3개
      • The speakers are located towards the bottom left and bottom right corners of the tablet.
      • If not already done, remove the black tape holding the wires down.
      • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
      댓글 쓰기
    2. APEX TM785CH Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 APEX TM785CH Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
      • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
      댓글 쓰기
    1. APEX TM785CH Circuit Board Replacement, Front Camera: 7 단계, 이미지 2개 중 1개 APEX TM785CH Circuit Board Replacement, Front Camera: 7 단계, 이미지 2개 중 2개
      • To get to the front camera, you will first need to remove the top panel.
      • Unscrew two 2.25 mm Phillips screws with a #00 screwdriver from the top plastic panel to remove it.
      댓글 쓰기
    2. APEX TM785CH Circuit Board Replacement: 8 단계, 이미지 1개 중 1개
      • Once unscrewed, use a spudger to pop the panel off by wedging it underneath the panel.
      댓글 쓰기
    3. APEX TM785CH Circuit Board Replacement: 9 단계, 이미지 3개 중 1개 APEX TM785CH Circuit Board Replacement: 9 단계, 이미지 3개 중 2개 APEX TM785CH Circuit Board Replacement: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • First, use plastic coated tweezers to pull up the black release tab.
      • Pull on the black connector with tweezers as close as possible to the white connector base, making sure not to pull on the connector base.
      • It is important to be careful not to damage the black connector tape or the white base.
      • Next, use the tweezers to peel off the tape holding down the connector to the front camera.
      • The front camera can now be removed from its socket.
      댓글 쓰기
    1. APEX TM785CH Circuit Board Replacement, Circuit Board: 10 단계, 이미지 3개 중 1개 APEX TM785CH Circuit Board Replacement, Circuit Board: 10 단계, 이미지 3개 중 2개 APEX TM785CH Circuit Board Replacement, Circuit Board: 10 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • After removing the top panel, battery, speakers, microphone, and front camera from the tablet, you will also need to use the tweezers to remove the connectors indicated in the same method as the previous step.
      댓글 쓰기
    2. APEX TM785CH Circuit Board Replacement: 11 단계, 이미지 2개 중 1개 APEX TM785CH Circuit Board Replacement: 11 단계, 이미지 2개 중 2개
      • Using a Phillips screwdriver, remove three 2.25 mm screws from the circuit board.
      • The circuit board can now be removed from the tablet.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brian Graschel
회원 가입일: 03/23/15
823 평판
안내서 6개를 작성함
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G1
3 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 26
전체 시간: 1,071
