주요 콘텐츠로 건너뛰기
ASUS MeMo Pad FHD10 Camera Replacement
Dmitry
Dmitry6 다른 기여자
최종 수정일 January 16, 2025
40 - 50 분
매우 쉬움
더 많은 이미지가 필요함
잘게 썰기
Use this guide to replace the front and rear cameras of your ASUS MeMo Pad FHD10 if they are not working or malfunctioning. This guide could also be used to adjust or clean the cameras in case of blurry camera's display or dislocation.
필요한 것
도구
더보기...
  1. ASUS MeMo Pad FHD10 Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Camera Replacement: 2 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Camera Replacement: 3 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Camera Replacement, Speakers: 5 단계, 이미지 1개 중 1개
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Camera Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Camera Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 3개
    • Identify the location of front and rear cameras on the motherboard.
    • The front and rear cameras can be removed by pulling them out gently using hands.
결론
작성자
6다른 기여자 명과 함께
Dmitry
회원 가입일: 01/21/15
391 평판
안내서 3개를 작성함
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G5
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 597
