주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Q405U Battery Replacement
필요한 것
  1. ASUS Q405U Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    댓글 쓰기
  2. ASUS Q405U Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    댓글 쓰기
  3. ASUS Q405U Battery Replacement: 3 단계, 이미지 3개 중 1개 ASUS Q405U Battery Replacement: 3 단계, 이미지 3개 중 2개 ASUS Q405U Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    댓글 쓰기
  4. ASUS Q405U Battery Replacement: 4 단계, 이미지 2개 중 1개 ASUS Q405U Battery Replacement: 4 단계, 이미지 2개 중 2개
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    댓글 쓰기
  5. ASUS Q405U Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
    댓글 쓰기
  6. ASUS Q405U Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Once all screws are removed, lift the battery out from the base of the computer.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jeremiah Baselice
회원 가입일: 10/25/21
569 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G8
4 회원들
안내서 5개를 작성함
1가이드 댓글
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 47
전체 시간: 2,757
