주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ROG Raikiri Pro Battery Replacement
필요한 것
  1. ASUS ROG Raikiri Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 ASUS ROG Raikiri Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 ASUS ROG Raikiri Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    댓글 쓰기
  2. ASUS ROG Raikiri Pro Battery Replacement: 2 단계, 이미지 3개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 2 단계, 이미지 3개 중 2개 ASUS ROG Raikiri Pro Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    댓글 쓰기
  3. ASUS ROG Raikiri Pro Battery Replacement: 3 단계, 이미지 2개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    댓글 쓰기
  4. ASUS ROG Raikiri Pro Battery Replacement: 4 단계, 이미지 2개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    댓글 쓰기
  5. ASUS ROG Raikiri Pro Battery Replacement: 5 단계, 이미지 2개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    댓글 쓰기
  6. ASUS ROG Raikiri Pro Battery Replacement: 6 단계, 이미지 2개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use a spudger to carefully remove the board and left rumble motor.
    댓글 쓰기
  7. ASUS ROG Raikiri Pro Battery Replacement: 7 단계, 이미지 2개 중 1개 ASUS ROG Raikiri Pro Battery Replacement: 7 단계, 이미지 2개 중 2개
    댓글 쓰기
  8. ASUS ROG Raikiri Pro Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the battery from its enclosure.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Yasmin Martinez
회원 가입일: 02/10/25
210 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 67
전체 시간: 847
