주요 콘텐츠로 건너뛰기
ASUS X533SA-BHCLN10 Optical Disc Drive Replacement
Edmund Lee
Edmund Lee4 다른 기여자
최종 수정일 December 15, 2017
25 - 30 분
조정
세부 사항 누락
In this guide we will be replacing your optical drive or CD-drive. If you are noticing that disks are not responding to your optical drive it is possible it is failing and you need to replace it with a new one. Optical drives are usually not too expensive and are easy to replace. With this guide you be able to efficiently and safely go through the process and be back to having a working replaced optical drive.
필요한 것
도구
  1. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 2 단계, 이미지 2개 중 1개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 3 단계, 이미지 2개 중 1개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 3 단계, 이미지 2개 중 2개
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: 4 단계, 이미지 2개 중 1개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: 4 단계, 이미지 2개 중 2개
    • Remove all 3 screws with the screwdriver.
    • The top left screw is 5.5 mm and the bottom two screws are 2.5 mm.
  5. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 1개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 2개 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Gently, push the optical drive part from inside to remove the drive from the motherboard socket.
    • While replacing, make sure the optical drive is connected to the socket of the motherboard (denoted by the red rectangle).
결론
작성자
4다른 기여자 명과 함께
Edmund Lee
회원 가입일: 09/26/17
473 평판
안내서 4개를 작성함
USF Tampa, Team S13-G3, Boczar Fall 2017 USF Tampa, Team S13-G3, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G3
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 213
