주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ATT CL2940 Buttons and/or Keypad Replacement
필요한 것
  1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    댓글 쓰기
  2. ATT CL2940 Buttons and/or Keypad Replacement: 2 단계, 이미지 3개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 2 단계, 이미지 3개 중 2개 ATT CL2940 Buttons and/or Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
    댓글 쓰기
  3. ATT CL2940 Buttons and/or Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
    댓글 쓰기
  4. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: 4 단계, 이미지 2개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: 4 단계, 이미지 2개 중 2개
    • Unscrew five 5.6 mm screws on top level, yellow motherboard.
    댓글 쓰기
  5. ATT CL2940 Buttons and/or Keypad Replacement: 5 단계, 이미지 3개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 5 단계, 이미지 3개 중 2개 ATT CL2940 Buttons and/or Keypad Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the top level Motherboard in order to get to the lower level Motherboard.
    댓글 쓰기
  6. ATT CL2940 Buttons and/or Keypad Replacement: 6 단계, 이미지 2개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
    댓글 쓰기
  7. ATT CL2940 Buttons and/or Keypad Replacement: 7 단계, 이미지 2개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew five 5.6 mm screws on the lower level Motherboard.
    • Keep the screws for the upper and lower level motherboard separated.
    댓글 쓰기
  8. ATT CL2940 Buttons and/or Keypad Replacement: 8 단계, 이미지 2개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the lower level Motherboard upward.
    • Remove the silicon pad above the buttons.
    댓글 쓰기
  9. ATT CL2940 Buttons and/or Keypad Replacement: 9 단계, 이미지 2개 중 1개 ATT CL2940 Buttons and/or Keypad Replacement: 9 단계, 이미지 2개 중 2개
    • Push the Button Panel upward and pull it out.
    • Replace the entire Button Panel or a single defective button.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Charles Messmore
회원 가입일: 02/15/16
577 평판
안내서 5개를 작성함
IUPUI, Team 1-1, Harley Spring 2016 IUPUI, Team 1-1, Harley Spring 2016 회원
IUPUI-HARLEY-S16S1G1
4 회원들
안내서 13개를 작성함
1가이드 댓글
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 39
전체 시간: 909
