AXIOO Pico M1110 PJM Hard Drive Replacement
15 분
조정
커뮤니티-기여 안내서
Identify the battery locker.
Set the righthand locker to unlock.
Pull the battery while setting the lefthand locker to unlock.
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Identify these:
4 keyboard clipper
Remove the keyboard clipper by gently twisting them till pops out.
Lift the keyboard up by pivoting on the bottom side.
Remove the following screw:
1 long Philips #0 screw
Remove the hard drive holder.
Pull the plastic tab away from the socket.
거의 끝나갑니다!
결론
