주요 콘텐츠로 건너뛰기
Access to RAM and CPU from why! W253EU
필요한 것
  1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 1개 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 2개 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3개 중 3개
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 1개 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: 2 단계, 이미지 2개 중 2개
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Access to RAM and CPU from why! W253EU: 3 단계, 이미지 3개 중 1개 Access to RAM and CPU from why! W253EU: 3 단계, 이미지 3개 중 2개 Access to RAM and CPU from why! W253EU: 3 단계, 이미지 3개 중 3개
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Access to RAM and CPU from why! W253EU: 4 단계, 이미지 1개 중 1개
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
결론
For reassembly, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 354
