주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer AL1916 VGA Input Replacement
필요한 것
  1. Acer AL1916 VGA Input Replacement, Stand: 1 단계, 이미지 1개 중 1개
    • Lay the monitor on a flat surface so that the back is facing up.
    댓글 쓰기
  2. Acer AL1916 VGA Input Replacement: 2 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
    댓글 쓰기
  3. Acer AL1916 VGA Input Replacement: 3 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
    댓글 쓰기
  4. Acer AL1916 VGA Input Replacement, Outer Case: 4 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement, Outer Case: 4 단계, 이미지 2개 중 2개
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
    댓글 쓰기
  5. Acer AL1916 VGA Input Replacement: 5 단계, 이미지 3개 중 1개 Acer AL1916 VGA Input Replacement: 5 단계, 이미지 3개 중 2개 Acer AL1916 VGA Input Replacement: 5 단계, 이미지 3개 중 3개
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
    댓글 쓰기
  6. Acer AL1916 VGA Input Replacement: 6 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 6 단계, 이미지 2개 중 2개
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
    댓글 쓰기
  7. Acer AL1916 VGA Input Replacement, EMI Shield: 7 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement, EMI Shield: 7 단계, 이미지 2개 중 2개
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
    댓글 쓰기
  8. Acer AL1916 VGA Input Replacement: 8 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 8 단계, 이미지 2개 중 2개
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
    댓글 쓰기
  9. Acer AL1916 VGA Input Replacement: 9 단계, 이미지 3개 중 1개 Acer AL1916 VGA Input Replacement: 9 단계, 이미지 3개 중 2개 Acer AL1916 VGA Input Replacement: 9 단계, 이미지 3개 중 3개
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
    댓글 쓰기
  10. Acer AL1916 VGA Input Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    • Remove the beige control cable to the left of the VGA input by pulling it up.
    댓글 쓰기
  11. Acer AL1916 VGA Input Replacement: 11 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the rainbow-colored power cable by pulling it straight up.
    댓글 쓰기
  12. Acer AL1916 VGA Input Replacement: 12 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the display cable located at the top of the motherboard by pulling it out towards the top of the monitor.
    댓글 쓰기
  13. Acer AL1916 VGA Input Replacement: 13 단계, 이미지 3개 중 1개 Acer AL1916 VGA Input Replacement: 13 단계, 이미지 3개 중 2개 Acer AL1916 VGA Input Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the three 7.7 mm Phillips #2 screws from the motherboard, and take out the motherboard by lifting it up.
    댓글 쓰기
  14. Acer AL1916 VGA Input Replacement, VGA Input: 14 단계, 이미지 2개 중 1개 Acer AL1916 VGA Input Replacement, VGA Input: 14 단계, 이미지 2개 중 2개
    • Set the circuit board down on its own, removed from the rest of the monitor.
    • Flip the circuit board over so that the VGA input is facing upwards.
    댓글 쓰기
  15. Acer AL1916 VGA Input Replacement: 15 단계, 이미지 3개 중 1개 Acer AL1916 VGA Input Replacement: 15 단계, 이미지 3개 중 2개 Acer AL1916 VGA Input Replacement: 15 단계, 이미지 3개 중 3개
    • Using the soldering iron, desolder the VGA input at the indicated locations.
    • Solder the new VGA input into the circuit board at the same locations.
    • Click here for more information on component-level soldering.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Taylor Atterbury
회원 가입일: 10/06/11
747 평판
안내서 3개를 작성함
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 회원
CPSU-MANESS-F11S20G26
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 44
전체 시간: 3,832
