주요 콘텐츠로 건너뛰기
Acer Aspire 1410 Disassembly
pollytintop
pollytintop6 다른 기여자
최종 수정일 January 11, 2019
1 시간
조정
커뮤니티-기여 안내서
To repair most parts on the Acer Aspire 1410 apart from HDD, RAM or battery it is necessary to disassemble the entire laptop computer. The motherboard is tricky to get to, and components are soldered on, but with perseverance, it can be done.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: 1 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: 1 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: 1 단계, 이미지 3개 중 3개
    • With laptop closed, turn screenside down and remove the battery.
    • Unscrew covers and remove HDD.
    • Unscrew cover and remove RAM.
    • Unscrew and remove cover for fan.
  2. Acer Aspire 1410 Disassembly: 2 단계, 이미지 1개 중 1개
    • Turn laptop so that hinges are closest to you and remove screw from rear of each hinge.
    • Remove screws securing bottom case to logic board. (It won't come off just yet though)
  3. Acer Aspire 1410 Disassembly: 3 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 3 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 3 단계, 이미지 3개 중 3개
    • Turn laptop over and open the screen fully. Take care as the screen is still connected to the logic board via black cable on right hinge.
    • Use a spudger to release the silver and black plastic cover that forms the hinge covers. Start at one side nearest a hinge and work along the rear of the case, there are 5 tabs to release along the keyboard edge.
    • Disconnect LCD cable by lifting straight upwards using the black plastic tabs on the top of the LCD connector. You may need to use a spudger to loosen the connection along the uppermost edge-not along the logicboard.
    • Remove 2 screws from left and right hinges.
    • Remove 2 screws securing topcase to rear of battery tray.
  4. Acer Aspire 1410 Disassembly: 4 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 4 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 4 단계, 이미지 3개 중 3개
    • Remove 2 screws securing power board to logicboard.
    • Lift LCD screen from bottom case.
  5. Acer Aspire 1410 Disassembly: 5 단계, 이미지 2개 중 1개 Acer Aspire 1410 Disassembly: 5 단계, 이미지 2개 중 2개
    • Remove 2 screws securing the keyboard to case.
    • Use a spudger to release tabs on all 4 sides of the keyboard. Do not pull keyboard up too far as the trackpad and keyboard flex cables are still attached to the logicboard.
    • Place ducks in sink, make sure to disinfect sink afterwards.
  6. Acer Aspire 1410 Disassembly: 6 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 6 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 6 단계, 이미지 3개 중 3개
    • Do not pull keyboard upwards as it is still attached to logicboard.
    • Flip keyboard over to cover trackpad. Disconnect keyboard.
  7. Acer Aspire 1410 Disassembly: 7 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 7 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 7 단계, 이미지 3개 중 3개
    • Disconnect trackpad.
    • Use a spudger to ease topcase free of bottom case. Slide topcase toward trackpad and then lift up. Resistance can be felt from magnets on topcase.
    • Your laptop should now look like this; middle photo is the remaining logicboard and bottom case, the last photo is the topcase cover.
  8. Acer Aspire 1410 Disassembly: 8 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 8 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 8 단계, 이미지 3개 중 3개
    • Remove logicboard screws.
    • Remove the 2 screws securing the modem.
    • Disconnect wire from the modem to the logicboard.
    • Disconnect the speaker wire form the logicboard.
  9. Acer Aspire 1410 Disassembly: 9 단계, 이미지 1개 중 1개
    • Use hex no.5 tool to unscrew 2 bolts from port next ac-in jack.
  10. Acer Aspire 1410 Disassembly: 10 단계, 이미지 3개 중 1개 Acer Aspire 1410 Disassembly: 10 단계, 이미지 3개 중 2개 Acer Aspire 1410 Disassembly: 10 단계, 이미지 3개 중 3개
    • Slide DVD drive from logicboard frame.
    • Slide logicboard toward trackpad and then lift out of logicboard frame. The logicboard has a pin connection to the battery tray preventing direct lifting of the logicboard.
    • Last 2 photo's show top of logicboard and underside of logicboard.
결론
To reassemble your device, follow these instructions in reverse order. Remember to place logicboard in ac power connection end in first
다른 22명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
pollytintop
회원 가입일: 06/09/10
77,348 평판
안내서 5개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 3개
superb thanx thanx thanx
thushararoshanperera - 답글
Great start, but this is not my 1410 and there is no selection for other models. The one I have is much smaller. Mine is model 1410-2817.
William Nelson - 답글
Great effort but my model does not mach, much smaller, 1410-2817.
William Nelson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 54
전체 시간: 17,625
