주요 콘텐츠로 건너뛰기
Acer Aspire 3000 Keyboard Replacement
Lykia Harper
Lykia Harper2 다른 기여자
최종 수정일 December 13, 2016
3 - 5 분
조정
This step-by- step process demonstrates how to replace an old keyboard on your Acer Aspire 3000. It is important to follow the steps carefully in order to prevent damage to the connectors or laptop itself upon removal of the keyboard. Damage to the connectors may cause a bad connection with the new replacement keyboard. Use caution to always remove the battery whenever you are repairing parts of your device.
필요한 것
도구
  1. Acer Aspire 3000 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3000 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3000 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  5. Acer Aspire 3000 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  6. Acer Aspire 3000 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire 3000 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  7. Acer Aspire 3000 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the two 4.6 mm Phillips #1 screws.
  8. Acer Aspire 3000 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  9. Acer Aspire 3000 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lykia Harper
회원 가입일: 10/29/16
258 평판
안내서 2개를 작성함
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 852
