주요 콘텐츠로 건너뛰기
Acer Aspire 3000 Screen Replacement
Austin Perona
Austin Perona2 다른 기여자
최종 수정일 December 13, 2016
20 - 40 분
조정
This guide will take you step by step through the process of replacing the screen on an Acer Aspire 3000. This process will involve removing the battery and keyboard as well, and will take roughly 30 minutes to complete
필요한 것
도구
더보기...
  1. Acer Aspire 3000 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 Screen Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 Screen Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 Screen Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
  5. Acer Aspire 3000 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Pop the three side tabs out of the back case.
  6. Acer Aspire 3000 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the panel that covers the graphics card.
  7. Acer Aspire 3000 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the black and white cables attached to the graphics card.
    • Be careful to lift vertically as to not mess up either part of the connectors.
  8. Acer Aspire 3000 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Push the white flanges on either side of the graphics card out.
    • The card should lift on its own slightly out of the case.
  9. Acer Aspire 3000 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the card by lifting up and away from the edge that has all of the contacts on it.
  10. Acer Aspire 3000 Screen Replacement, Keyboard: 10 단계, 이미지 1개 중 1개
    • Lift the laptop to be on its edge, with the bottom of the screen in the air.
  11. Acer Aspire 3000 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 4.6 mm Phillips #1 screws that are on this edge.
  12. Acer Aspire 3000 Screen Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Wedge a spudger into the latch on the right side.
    • Open the lid completely to facilitate removal.
    • Pull the handle of the spudger towards you to pop the first of the tabs that hold this piece in place.
    • Starting from right to left, pop the remaining tabs by lifting up on the panel and rotating the panel to the left.
  13. Acer Aspire 3000 Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Unscrew the two 4.6 mm Phillips #1 screws.
  14. Acer Aspire 3000 Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Gently lift the top edge of the keyboard out of its place.
    • Do not completely remove the keyboard as there is still a ribbon cable connecting it to the device.
  15. Acer Aspire 3000 Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the ZIF connector's black retaining flap. Then gently slide the ribbon cable out.
    • Remove the keyboard.
  16. Acer Aspire 3000 Screen Replacement, Screen: 16 단계, 이미지 1개 중 1개
    • Lift the connector attached to a black cable that leads to the screen of the laptop.
    • Be sure to lift vertically, moving your hand slightly towards and away from you as necessary to gently separate the connectors.
  17. Acer Aspire 3000 Screen Replacement: 17 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Using a spudger, free the grey cable from underneath the plastic bars holding it within the body of the laptop.
  18. Acer Aspire 3000 Screen Replacement: 18 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 18 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 18 단계, 이미지 3개 중 3개
    • Rotate the laptop to where it is standing on its side.
    • Take the black and white ended cable that was disconnnected earlier and straighten it out on the underside of the laptop.
    • Pull the cable through to the keyboard side of the laptop.
  19. Acer Aspire 3000 Screen Replacement: 19 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 19 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 19 단계, 이미지 3개 중 3개
    • Unscrew the four 4.6 mm screws located here.
    • Unscrewing one screw from each side at a time and then supporting the screen as the final screws are removed will help protect the laptop's components.
  20. Acer Aspire 3000 Screen Replacement: 20 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 20 단계, 이미지 2개 중 2개
    • Lift the screen and its casing away from the laptop.
  21. Acer Aspire 3000 Screen Replacement: 21 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 21 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Using a spudger, push the four rubber circles covering the screws for the upper casing.
    • Unscrew the four 4.6 mm screws that were just uncovered.
    • There may be some residual adhesive on the top of the screws, this will not harm the driver as you remove the screws.
  22. Acer Aspire 3000 Screen Replacement: 22 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 22 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 22 단계, 이미지 3개 중 3개
    • Begin prying apart the two halves of the screen casing, starting at the bottom near where the cables enter the casing.
    • The process for separating the two halves is to take a spudger, inserting and twisting it until the tabs holding the casing together audibly pop.
    • Slide the spudger down the divide between the casings, twisting it whenever a tab is encountered to release it.
  23. Acer Aspire 3000 Screen Replacement: 23 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 23 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 23 단계, 이미지 3개 중 3개
    • After the bottom has been freed and the side of the casing has started to separate, one's hands can be used safely to pry apart the rest of the casing.
  24. Acer Aspire 3000 Screen Replacement: 24 단계, 이미지 3개 중 1개 Acer Aspire 3000 Screen Replacement: 24 단계, 이미지 3개 중 2개 Acer Aspire 3000 Screen Replacement: 24 단계, 이미지 3개 중 3개
    • Release the two connectors from the screen to the circuit board on the bottom of the casing.
    • Unscrew the grounding screw for the black cable.
  25. Acer Aspire 3000 Screen Replacement: 25 단계, 이미지 1개 중 1개
    • Undo the four 4.6mm screws located above and below the screen.
  26. Acer Aspire 3000 Screen Replacement: 26 단계, 이미지 2개 중 1개 Acer Aspire 3000 Screen Replacement: 26 단계, 이미지 2개 중 2개
    • Remove the two lateral 4.6 mm screws on each side of the screen.
    • 'To avoid stripping out the screws, this step may require you to lift the screen away from the case to access the screws.
  27. Acer Aspire 3000 Screen Replacement: 27 단계, 이미지 1개 중 1개
    • Tilt the top of the screen out of the case towards you, and then separate the screen from the metal frame that secures it to the casing and remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Austin Perona
회원 가입일: 10/30/16
137 평판
안내서 1개를 작성함
Baylor, Team 4-2, Williams Fall 2016 Baylor, Team 4-2, Williams Fall 2016 회원
BU-WILLIAMS-F16S4G2
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 1,297
